1995 gts recommendation for distributor cap and rotors
I've never heard of a a couple of those brands - are you from outside the U.S.?
I've used Standard, Delco and Motorcraft and they all did fine.
I've had bad luck with msd caps, actually I have a taylor cap and rotor and i like it, ive tried alot of diff brands motorcraft, acdelco and taylor have all been good to me. never skimp on ignition parts it will come back to haunt you later.
Yeah, the MSD Dizzy has had a bad reputation. I've never had good luck with them. The thing to look for is the metal parts of the cap and rotor. A quality cap and rotor will have brass instead of aluminum. The best used to be the Accel cap (the ugly brown one). The Accel one was assembled first, and then the inner circumfrence was machined after assembly. This process guaranteed a perfect gap between the rotor and all the points. Accel also used to make their caps with thicker plastic making them more consistent. All the other companies machined the parts seperately, and then pressed them in afterwards. However, Accel has stopped doing this with their caps. They are selling the same crap as everyone else now.
Kurt
