1995 Mustang Cobra
logistix
I would like to know what the next thing I should do to my car to get more power other than obviously a supercharger. In your opinion, what should I buy next based off of what I have already got done?
12" K&N Air filter in the fender
C&L Trueflow Intake
BBK 70mm throttle body
Edelbrock Performer RPM Upper and Lower Manifold and Plenum
Crane Roller Rockers (Stock)
Cam is stock
Stock Heads (GT40)
Tremec TKO 600 Transmission
MSD Distributor and Blaster Coil
Aeromotive Fuel Pressure Regulator
2004 Cobra Fuel Pump
Ford Racing Spark Plug wires
Motorcraft AWSF32C spark plugs
JBA Shorty Headers
BBK X-Pipe
Centerforce Dual Friction Clutch
Magnaflow Magnapack exhaust
Ford Racing 3.73 Gears
2004 Cobra Eaton Differential
Ford Racing Aluminum Drive Shaft
12" Mickey Thompson ET Streets Radials on Weld Draglites
Stock MAF and stock injectors 24lbs.
Air/Fuel Ratio ?
Timing ?
No tune that I know of
need more power
timeless2 i should have mentioned that there are new KYB G2 struts up front with lowering springs and in the rear i have some edelbrock red lower control arms a subframe connector and lowering springs. I don't have a stabilizer bar under the hood and I'm pretty sure I'd have to look again to see if there are upper control arms.
