1995 Saleen S351-R #76
eddie33
Some of you may have seen this on Stangnet before, but now it's at a lower price. $27,000
1995 Saleen S351-R, Supercharged. This is a one of one out of 132 for 1995 according to Saleen records. It is number 76 of that year. The motor was professionally built with performance and drivability in mind. The motor has about 8000 miles on it now. It makes 525 RWHP on pump gas. The motor can easily be made to make about 800hp with some minor changes. This car is for serious enthusiasts only as it is a collector's item, super car, and a show car as well. The list of parts in the motor are extensive and I'll try to cover most of it in addition to other modifications.
Sony stereo is paired to the factory Mach 460, joined with a Rockford Fosgate amp and 10" twin Punch woofers in a custom fit trunk box. There is also a CD changer that goes with it that is not installed. The car alarm is paired with the factory remote system and works perfect.
I only included the basic pictures to keep the cost of the ad down. I have tons of pictures and a notebook full of receipts and specs.
The car has won many trophies and has been featured in magazines, calendars, Saleen Club of America clock 2007, and car of the month on GTR Hi Performance's web site.
Signed by Steve Saleen on the dash and firewall.
351 Windsor/ 408 Stroker, Balanced
Vortech S trim supercharger
race bearings
Canton 7qt pan
351w pro series pick up
Custom hydraulic roller cam
aluminum roller rockers
Manley chrome moly push rods
Ford hydraulic roller lifters
AFR 185 CNC heads (smog legal capable)
Mahle dish piston (formula one style 1000 HP capable)
9.2:1 compression ratio
Stewart High-Flow water pump
Fel-Pro gaskets
Urethane motor mounts
Fluidyne 2-Row radiator
AFM Power pipe (intake)
Accufab 75MM Polished billet aluminum throttle body
Ford Racing 90MM Lightining Mass air meter
Ford MAF lightning wire harness
Kenne Bell 90MM Mass Air Adapter
Diablosport MAF extender
Mafia device
Chip Master Revoltion module (custom tuned)
47 lb. injectors
New Thermostat and housing
Balanced fly wheel
Ram balanced kevlar clutch
K&N Hi flow filter (in fender)
Fel-Pro intake gasket
BBK upper to lower intake gaskets
Stainless Vortech oil line hose
Steeda adjustable fuel pressure regulator
Kenne Bell 40 amp boost-a-pump
Royal Purple synthetic oils
Saleen Alcon front brakes
Baer big brake kit rear brakes with Hawk pads (slotted to match front)
J&M Upper control arms
J&M Lower control arms with ride height adjusters
Steeda full length Sub frame connectors with cross brace (welded)
Maximum Motorsports Caster/Camber plates
Kumho Ecsta MX (ZR rated) 295/35/18 and 265/35/18 tires
Steeda Firewall Clutch adjuster
Steeda double hook Billet aluminum clutch quadrant
Steeda Oil separator kit (2)
MSD wires and cap
MSD ignition
BILLET/ POLISHED STUFF:
Door lock pins
Saleen pedals
Tilt steering lever
Heat & a/c knobs
Shifter knob
E-brake handle
Headlight knob
Turn signal knob
Defroster switch
Shorty antenna
Radiator Cover
Oil filler cap
Brake reservoir cap
Fuse Box cover
Upper intake
Intake tube
Alternator
Supercharger
Power pipe
Throttle Body
Eddie
951-316-one seven eight six
