Gasket questions
I have a bad controller on my IMRC
somebody give me the gasket info? factory ford are composite reuseable? i would like to have an extra set in case i need them at breakdown time. i see felpro makes some but are they just paper gaskets? do you use sealant with the composite? im guessing you will for sure on paper if the felpro are not composite? is it 5 gaskets you need? above and below the IMRC delete plate the same gasket?
