1997 Mustang key will not remove from ignition
Okay I'm a locksmith the first thing I'd do is squirt some tryflow or WD 40 in it and tap the key with a screw driver and wiggle it. It's most likely a stuck wafer not allowing the key to release. If that don't work take it out and take it to a locksmith Yours should be a poke and pull to get the ignition out turn the key to the on position on the underside of the column there is a small hole under the ignition stick an ice pick or some coat hanger in there and depress the button and pull and it will come out. good luck.
