  • 2005 - 2009 Specific Tech
1st Gear Bog
  • Thread starter Thread starter 5ohno
  • Start date Start date Mar 16, 2012
5ohno
  • Mar 16, 2012
I have a 2007 GT with a TR-6060, full exhaust, and Saleen blower, and 4.10 gears. I believe something is wrong with the traction control. Even with the traction control button off, the car acts like traction control is active in first gear. After first gear, the car runs like a scalded dog. It has been professionally tuned and built. Any ideas what this problem may be?
5ohno
  • Mar 16, 2012
TTT! Really need help here!
Admin Dude
Jan 4, 1985
43,541
21,709
234
Box behind Walmart
Mar 16, 2012
  • Mar 16, 2012
Pull codes. Initial instinct is TPS.
5ohno
  • Mar 16, 2012
The engine light is not on. Shouldn't it be if a code is thrown? Shouldn't the car act up in the other gears also?
Admin Dude
Jan 4, 1985
43,541
21,709
234
Box behind Walmart
Mar 16, 2012
  • Mar 16, 2012
Not necessarily, depends on what's actually wrong.
If the TPS is acting up then the symptoms would lessen once the throttle body was open and RPMs were up.
Just spit balling though. Pull codes.
5ohno
  • Mar 16, 2012
I tried pulling codes with the old programmer I had for it. The programmer said no codes are being thrown.
Admin Dude
Jan 4, 1985
43,541
21,709
234
Box behind Walmart
Mar 16, 2012
  • Mar 16, 2012
Hmmm...
he
I'd ask for your AFR but many folks don't run a wideband.
Check timing.
With the car off and key on, put a meter on the TPS and measure voltage. Manually operate the throttle and ensure that voltage is scaling as throttle blade moves.
Run KOER if you haven't already.
5ohno
  • Mar 16, 2012
It's definitely not a tune related issue. Timing and AFR are fine. I'm not sure about the TPS voltage though.
5ohno
  • Mar 16, 2012
I will say this. I've been through three transmissions. After the stock one was replaced with a TKO-600, the car started doing this. Are there any wires or parts that could've been damaged during a transmission swap?
5ohno
#10
  • Mar 17, 2012
  • #10
I took the car out this morning and it acted fine. I thought it could be a problem when warmed up, but it acted fine after it reached operating temp also. This bug has me stumped.
SpartaPerformance
2,517
61
89
Long Island NY
Mar 17, 2012
#11
  • Mar 17, 2012
  • #11
Burned clutch?
mustangmike6996
5 Year Member
Nov 10, 2005
483
clinton twp, MI
Mar 17, 2012
#12
  • Mar 17, 2012
  • #12
is the car bucking or just has a hard time taking off/ very poor accel? could be cam timing being too retarded. make sure your air intake tube is fully seated on the throttle body as well.. ive seen this cause similar symptoms
5ohno
#13
  • Mar 17, 2012
  • #13
The clutch has about 500 miles on it. It's a McLeod Stage 3. It's not bucking. It's not a timing issue. The intake tube is sealed. The feels almost identical to traction control kicking in.
5ohno
#14
  • Mar 17, 2012
  • #14
Like I was saying, it has no problems past 1st gear. It doesn't act up in 1st all the time either.
P
2000 GT Random Power Loss
  • Pinellas50
  • Mar 9, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Mar 23, 2026
Pinellas50
P
J
Reduced power in 1st and 2nd gear
  • jimted79
  • Feb 25, 2025
SN95 4.6L Mustang Tech Feb 25, 2025
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
R
94’ SN95 - Intermittent lope & bogging at moderate rpm
  • Red5.0ho
  • Nov 2, 2025
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech Nov 3, 2025
General karthief
