Some of you may have seen the new Barry Grant inline 4 barrel carb that's coming out soon (if not already). With the barrels better spaced relative to the intake ports it has much better fuel distribution picking up more HP and Tq. Unfortunately it's so unique in design that you only have one manifold to chose from, and that's of course for the small block Chevy. But that made me think that an easier way to accomplish the same thing would be to arrange a couple of two barrel carbs sideways, so the barrels are spread out longitudinally. Of course that still requires a custom intake, so the next best thing to do would be to use an existing 2-4 manifold and use adapters with 2 2 barrels. It may be a lot of work to go through for little gain, but I wonder if it would be more driveable than with 2 4s?? I have too many experiments going on already, so I need to leave my engine alone, but if someone already has a 2-4 set up, maybe you could throw a couple of Autolite 2100s on it and do a test drive?.
Holley 500 2 bbls are exactly half of a 750 DP. Same throttle bore size, same venturis. In any case, the flow ratings are moot as far as what the motor will draw thru whatever you bolt to the intake. The rated flow is only to be used as a guide in choosing a carb. What it actually will flow at WOT on the engine is not what the rated flow listed is. For the rated flow to be duplicated, the engine would have to be pulling the same 1-1/2"HG at WOT (4 bbl rating) And that will virtually never happen, there's too many variables involved (cams, heads, intake, exhaust,etc) When I had the 331 in my 89 Ranger it would top in at 90mph on the center carb, at that speed, the motor at 100% VE would be drawing 386 cfm thru a 250 cfm rated carb. This motor more than likely pulls 100%VE with Canfield heads, and a Z303 cam using 1.7 rockers to increase the lift. The whole point of doing two 2 bbl carbs is purely as an experimentation, and simply doing something different, so you may as well forget talking us out of it, cause your not going to
