2.25 or 2.5 inch exhaust.
  • Thread starter Thread starter Edster
  • Start date Start date Sep 26, 2010
  • 3
1 of 3 Next Last
Edster
500
League City, Texas
Sep 26, 2010
  • Sep 26, 2010
I'm wondering which would be best. 2.25 or 2.5. I"m runnin a 302 .030 over w/ D0OE heads that have had some mild porting done and have anywher between 10.5:1 to 11:1 compression w/ an Edelbrock perfoemer rpm power package. I think a 2.25 would suffice but also wonder if a 2.5 would be better or am I just wasting my money. Any thoughts?
Az Pete
711
18
49
Panama City, Fl.
Sep 26, 2010
  • Sep 26, 2010
My 289 is 10:1 with 2.25" exhaust with no problems. Been that for a long time.
Edster
500
League City, Texas
Sep 26, 2010
  • Sep 26, 2010
AZ Pete, thanks for your service in the Air Force. I'm retired Navy myself. I reckon that a 2.5 was overkill anyway. I had the same engine in a Falcon with 2.25 and had no trouble either. I was just wonderin if I had anything to gain w/ a 2.5 inch.
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Sep 26, 2010
  • Sep 26, 2010
Here is the chart that Magnaflow puts out for this:
MagnaFlow Performance Exhaust - FAQ, Frequently Asked Questions
2+2GT
3,333
10
79
Southeastern Pennsylvania
Sep 26, 2010
  • Sep 26, 2010
That chart is surprisingly useless, they indicate a 289/302 should have 2" to 2-1/2" exhaust. If you look at the cross section area, that's about 3.14 square inches on a 2" pipe, and 4.9 square inches on a 2.5" pipe, a whopping big difference.
Realmongo
2,466
86
99
Western Mass
Sep 26, 2010
  • Sep 26, 2010
Probably emphasizing a minimum and maximum for the the application.
2+2GT
3,333
10
79
Sep 26, 2010
  • Sep 26, 2010
Sure, but it's such a wide range as to be useless for deciding between stock 2" duals, or very non-stock 2.5".
It's also worth noting that the 67 GT500 428 dual-quad Shelby had 2" exhaust.
But then, even the BOSS 429 had only 2.25".
Something to watch out for is various fads for "bigger is better".
In my automotive life, I have seen fads for bigger
•rear tires. L60-15 was the ticket, and required High-Jackers to clear. Cornering was out of the question.
•coils. More powerful, of course, but large size with cooling fins was equally important.
•carburetors. If a 600 was good, 650 was better, and 750 double-pumpers guaranteed the jump to lightspeed.
•spark plug wires. Summa these things are starting to look like heater hoses.
•exhaust. I've seen pipes on Toyotas that would do a Peterbuilt proud.
There's a point of diminishing returns on size, for example, a 3-row radiator is maybe 50% better than a 2-row, but a 4-row is only about 10% better than a 3-row.
So, does a 302, even a really hot one, really require a coil four times as powerful as the one on Mickey Thompsons 427 Hemi Ford Thunderbolt?
Wicked65
490
NORCAL
Sep 27, 2010
  • Sep 27, 2010
Id go with 2.5in. Reason being, if you have ever driven even a fairly stock 5.0 with stock exhaust, and then felt the difference with 2.5, or better yet a cat less x pipe, there is a fairly big difference. I guess the biggest thing with your car is the port work that has been done, and the higher compression, why make the exhaust the restriction?
horseballz
824
Las Vegas, NV
Sep 27, 2010
  • Sep 27, 2010
The 2.5" Magnaflow is such a great deal, when purchased through StangNet, that it seems to be a no brainer. From my searching, any other system, even a 2.25" that even comes close to the quality/features (including lifetime warranty) will cost as much if not more. To get the killer price, you need to follow the special pricing link on the Exhaust page, after you figure out which part number system you need/want. Unfortunately, Magnaflow doesn't make a 2.25" for our early Mustangs.
Just My $.02,
Gene
woodsnake
1,352
15
69
Hicksville, NY
Sep 27, 2010
#10
  • Sep 27, 2010
  • #10
--------2.5------
The only way to go on a small block that has even just a better set of plug wires...
brianj5600
1,964
Middle TN
Sep 27, 2010
#11
  • Sep 27, 2010
  • #11
I would do 2.5". Down the road you want N2O or a 347 with good heads on it and have to buy again if you go 2.25". I wish I had done 3" on mine.
tx65coupe
Sep 28, 2010
#12
  • Sep 28, 2010
  • #12
I have 2.5 inch exhaust on mine, but could have done just fine with 2.25.
Since that Magnaflow kit is such a good deal, I would probably just go with it. Does it have an H pipe?
I don't think 3 inch duals is needed on anything except maybe a really hot big block.
horseballz
824
Las Vegas, NV
Sep 28, 2010
#13
  • Sep 28, 2010
  • #13
Magnaflow has an "X" pipe.
tx65coupe
Sep 28, 2010
#14
  • Sep 28, 2010
  • #14
Oh. Its too bad it doesn't have an H pipe instead.
Vinyl66
398
#15
  • Sep 28, 2010
  • #15
Undoubetedly 2.5". Do not crutch a V8 with any less.
brianj5600
1,964
Middle TN
Sep 28, 2010
#16
  • Sep 28, 2010
  • #16
What about an 800hp 351w?
horseballz
824
Las Vegas, NV
Sep 28, 2010
#17
  • Sep 28, 2010
  • #17
tx65coupe,
You said:
"Oh. Its too bad it doesn't have an H pipe instead." Please explain. Is an "H" pipe better than an "X" pipe and why? From what I can tell it seems a topic of spirited debate with only minimal differences. I could be wrong. But if you click on the exhaust link near the top of the page, scroll down to the setup for your car and click the part number, it will link you to the Magnaflow site with an expandable pic that shows all the parts that appear to be quite well made with many good reviews throughout the internet.
Gene
blown65
1,938
Queen Creek Arizona
Sep 28, 2010
#18
  • Sep 28, 2010
  • #18
There's gains on even my motor with 3" duals at its little 347 cu inch. 2 1/2 would be too small.
That magnaflow chart seems pretty good to me if you go by HP of the engine. I'm sure most 2 1/2 is more than sufficient on this site.
rbohm
6,698
550
204
tucson,az
Sep 28, 2010
#19
  • Sep 28, 2010
  • #19
personally i prefer 2.25" pipes on my mustang. as for H pipe vs X pipe, both have their advantages, i think the X pipe is a better choice.
65FBE2
283
Minnasnowta
Sep 29, 2010
#20
  • Sep 29, 2010
  • #20
I had a 2" system with cherry bombs on a 289. I ran a best time of 12.83 with nothing more than a solid cam, 650 Holley and headers. The car ran within a tenth with open headers as it did with the full exhaust. Anything short of a full on rece motor does not need 2.5". This is the same as the guy who has a stock 289 with a 480 cfm autolite, bolts on a holley 600 and says wow what a different's that made! And it actually lost power and slowed down. Most of the power gains in a 2.5" system are in your head and not real. Just my 2 cents
  • 3
1 of 3 Next Last
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
Idle spark confusion
  • sav22rem22
  • Oct 26, 2023
  • Digital Self-tuning Forum
2K
Digital Self-tuning Forum Nov 1, 2023
sav22rem22
D
Building a 302 and Require Input
  • dduran
  • Jun 15, 2020
6K
1965 - 1973 Classic Mustangs -General/Talk- Jul 18, 2020
DBegley
D
