Ok not a mustang but my boat has a 87 Ford 2.3L engine and maybe you guys can help??
Recently the engine was running good all morning until the end of a 15 min ride at near WOT. The engine did not over heat, or make noises really, It just stopped suddenly at near WOT and would not fire after that. Got it home on the kicker...
I checked the compression and all are good at around 165-175 psi on a Cold engine. I checked spark and a good spark was present, checked for fuel and the carb sprayed when the throttle was depressed. checked the timing belt, it aligns with the timing 0 mark on crank, checked rotor position and it seemed to be pointing at #2. I got it running by aligning the distributer to #1 on tdc. The timing belt is aligning right... But it seems the distributer is getting out of wack somehow...As i was timing it to 10* the thing started going down the timing grid and finally went below 0 and stalled out.
It has a mallory distributor points style.
Any help?
Any help?
