  • 2.3L (N/A & Turbo) Tech
2.3l tech
  • Thread starter Thread starter Techboi
  • Start date Start date Nov 6, 2024
Techboi
Houston
Nov 6, 2024
  • Nov 6, 2024
Hey guys I’ve got a 91 with a 2.3l and a4ld and currently it’s been broken down for about 2 months now and so far I’ve installed a new starter, starter solenoid, ignition coils both of them, fuel pump and fuel filter and a fuel pressure regulator and it still won’t start it cranks but there is no power to the ignition coils and no power to the fuel pump and I’m honestly tired of mindlessly throwing money at it when I don’t know what the actual problem is so if anyone has any insight that would be great if someone could come by to take a look at it I will compensate for travel and time spent
89ripper
925
309
103
Rockford, Illinois
Nov 8, 2024
  • Nov 8, 2024
Giving you a bump hopefully someone can chime in. Im unfamiliar with 2.3 starting procedures but so long as the wiring, grounds, connections are clean, relays are in proper function the next thing I would check is your ecu function. Also ignition module wiring as well.
Techboi
Houston
Nov 8, 2024
  • Nov 8, 2024
So my friend who is a mechanic said that the constant control relay module as well as the ignition control module needs to be checked then testing the wires with a light tester
89ripper
925
309
103
Rockford, Illinois
Nov 8, 2024
  • Nov 8, 2024
Im glad you have some assistance with this. I know more about my 5.0, and even then still learning some new things everyday. I am just a resident thread bumper around here
Update the thread if you could when you figure it out or if you still need help
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
  • dan50
  • Jul 18, 2026
dan50
Engine Misfire below 3K RPM
  • foxbodyclark
  • May 25, 2025
Fox 5.0 Mustang Tech May 31, 2025
General karthief
Electrical Crank-no start ... no spark ... no injector pulse, was it something I did? (redux)
  • 85gtCOBRA
  • Oct 28, 2025
Fox 5.0 Mustang Tech Oct 29, 2025
85gtCOBRA
