2 inch lowering springs?
wcharrison39
Sumter SC
I recently ordered 2 inch lowering springs with shocks and struts, i know i will need cc plates as well. I have 17x8 rims/245/45 tires on a 90 gt, will this be too low of a drop? Is there anything else needed to complete the install? It is not a daily driver and i am more worried about looks and handling than a comfort ride. Any advice will help
Welcome to the boards!
A little info about the car might be helpful. :)
Which springs are you contemplating? Are you going to install new isolators?
all of my suspension is stock, its a 90 gt and i just put a 351 in it so i was starting on the handling next. i just bought the rims and tires on 50resto so i figured i would get the springs as well. havent installed anything yet though. i wanted to do it right though i just dont know much about suspension.
x2, I have 1.5 lowering springs, same size tires as you and mine rub on a good turn or good bump. Plus Im in a 5.0. Im not sure of the amount, but the 351 should weigh a little more. Something to consider since the drop is more than likely measured under the weight of a 302. Weight difference could be as easy as a battery relocation to return it to normal though. Something to look in to.
