2 piece distributor
  • Thread starter Thread starter DCEVING84
  • Start date Start date Mar 8, 2006
DCEVING84
Sacramento
Mar 8, 2006
  • Mar 8, 2006
Hey i just picked up a procomp ignition system for my 84 mustang. i blew the motor up and i got a 302 out of a 87 truck or something. i was trying to install the new distributor and i noticed that the gear was actually a seperate piece that comes off real easy. i guess it is for a early 302. i was wondering if it would still work for my car. thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 8, 2006
  • Mar 8, 2006
Roller cam engine = steel distributor gear. Flat tappet cam = iron gear.
rd
3,316
63
109
Ocean Springs MS
Mar 8, 2006
  • Mar 8, 2006
Yes they are removable, ususally needs a press, puller or similar persuasion.
They can be changed, although some effort may be needed to shim it correctly and get the rolll pin to line up. Note that there are two shaft diameters for small block dist's.
DCEVING84
Sacramento
Mar 8, 2006
  • Mar 8, 2006
it is a roller motor. do i need to press the gear on or could i run it with the way it is now. so as long as the shafts are the smae size it should work right.
thanks
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
Mar 8, 2006
  • Mar 8, 2006
Roller motor means you need a steel gear to keep from chewing up the iron gear and depositing metal particles in the oiling system.
9
90lxfoxbody
264
  • Mar 8, 2006
i bought a new procomp distributor and noticed the same thing. i put a little blue threadlocker inside the bottom piece then set the top piece in place. i wiped away the excess then let it sit upright in the box it came in overnight. next day it held tight and installation went just fine. not sure if that's the recommended method, but it's been 500 miles and no problems yet.
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Engine Distributor Interchange List
  • Wayne Waldrep
  • Jun 21, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2026
dan50
Resolved Does anybody recognise this distributor gear?
  • x_man586
  • Jun 4, 2025
Fox 5.0 Mustang Tech Jun 24, 2025
x_man586
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Mustang II 4 cyl gear hunting and possibly messed up vacuum system
  • oesterreicher
  • May 31, 2026
1974 - 1978 Mustang II Talk & Tech Jun 14, 2026
manicmechanic007
