2 questions unrelated
  • Thread starter Thread starter jimdrechsler
  • Start date Start date Apr 21, 2007
jimdrechsler
248
Apr 21, 2007
  • Apr 21, 2007
1) I have an adjustable clutch- one that i can adjust from teh firewall. i went and made it so it catches lower towards the floor. after this, i noticed that at the top of the clutch i have about 3 inches of play where i can puch it down and it pops up. is this normal? it isnt smooth until you pass the couple inches going down. the clutch seems fine otherwise.
2) can people help me decide which tire to go with. im looking for the cheap route seeing as how i ordered DR's from jegs like a dumbazz. here is what i have to choose from...
http://www.discounttiredirect.com/direct/searchTiresBySize.do?sw=false&cs=225&ar=50&rd=16
thanks
873Stang
221
riverside
Apr 21, 2007
  • Apr 21, 2007
WHAT EVER YOU DO DON'T GET THE K106, YOU WILL HATE IT!!!!!!! THATS WHAT I HAVE ON MY 87 COUPE AND NO TRACTION AT ALL
EMW150
2,020
Roaring Spring,PA
Apr 21, 2007
  • Apr 21, 2007
It sounds like you have too much freeplay in the clutch. They should be set snug to get proper release which will give you a pretty high pedal.
88mouse
630
Mooresville nc
Apr 21, 2007
  • Apr 21, 2007
you better watch that poping my car and my buddys did that and the cable broke. I like my pedal about an inch from the top.But set it where ever it feels best to u.
cenok is family
1,409
69
79
Norman, Ok
Apr 21, 2007
  • Apr 21, 2007
yeah adjusting it to grab lower is shortening the cable so you end up either stretching the cable or snapping it all together. i try to put mine in the middle, a little more towards the top.
jimdrechsler
248
Apr 21, 2007
  • Apr 21, 2007
thanks- ill adjust so it catches higher.
any input on those tires?
thanks,
jim
RYC CUKR
1,437
Orlando
Apr 21, 2007
  • Apr 21, 2007
Personally I would probably go with the Nittos. Stay far away from the Hankooks. We put a set on our Mach 1 and they were fine for about 10k but once they started to wear they would track really bad when driving. Any road inperfection or groove and they would try to follow right along with it. Went with a set of Nittos and I have been very happy with them.
jimdrechsler
248
Apr 23, 2007
  • Apr 23, 2007
any other input on tires. i want to order today!
jimdrechsler
248
Apr 25, 2007
  • Apr 25, 2007
ttt
90_Red_LX
668
Asheboro, NC
Apr 25, 2007
#10
  • Apr 25, 2007
  • #10
I run the falken ziex 512s listed on that site. They hook very well for the price. Full exhaust, intake manifold, and gears cut a 1.90 60' at the 1/8th track. They also do pretty decent with the h/c/i setup, just pedal the gas and slip the clutch a little. A hard shift to 2nd will break them loose though.
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
Progress Thread The Mach Returns - Update/build thread
  • squeak93
  • Feb 20, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 19, 2026
squeak93
