2 ?'s i need answers two asap!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
putnam88
102
tavares
ok first off i have a jumpy idel bounces from 500 to 1000 RPM
second off stock injectors on a 1990 mustang 5.0 is 19 lbs and i am putting a 347 stroker in it i wanted to know is 19 lbs good or like 24's???
true
thats what i thought but then i have also heard that if u get ur comp reflashed then the 19's will work just fine and i know that putting like 40's on there would be over kill cause that would be like a graden hose of fuel and im not dragging it profesionaly so...
Make sure you throttle position sensor is working correctly to fix you idle, also you might want to go with some 30lb injectors for that 347 and a bigger fuel pump, at the very least 190lph, but i would suggest 255lph.
Why a bbk intake? Definatly NOT what i'd use with 205's on a 347. What cam? What size exhaust? You need 1 3/4" and a 3" exhaust.
You need 36-42lb injectors and a 255 pump.
