2000 3.8 feels slower than my 2004 3.9
Kingll
Mississippi
I bought a 2000 convertible mustang it feels way slower than my 2004 coup. The 2000 was supposed to be a standard but the previous owners converted it to a auto and use a 01 computer and trany plus wireing harnes. As a result some of the sensors didn't work but i switched the computer out with a one from a 2000 to get the sensors working. Now i have codes for the o2 sensor but that is probably because of the wire harness. The big problem is how noticeable the difference in acceleration and response is. Is something wrong with the trany or is the culprit the big 18" bullitt rims and tires that scrubs.
The convertible weighs more than the coupe, that's the first reason it's slower. Second, if your check engine light is on for O2 sensor codes, it's running in "limp home" mode beause the PCM can't accurately determine air/fuel ratio, find the cause of that and correct it.
Yes, its overkill on the information, but I am bored at work
2000:
3.8L V6 Coupe.......................3069 lbs
3.8L V6 Convertible................3211 lbs
4.6L V8 Coupe.......................3237 lbs
4.6L V8 Convertible................3400 lbs
2000 Cobra R.........................3600 lbs
2004:
3.8L V6 Coupe.......................3066 lbs
3.8L V6 Convertible................3208 lbs
4.6L V8 Coupe.......................3241 lbs
4.6L V8 Convertible................3379 lbs
Cobra Coupe .........................3665 lbs
Cobra Convertible .................3780 lbs
Mach 1..................................3465 lbs
This is for me lol
1995:
3.8L V6 Convertible................3245 lbs
5.0L V8 Coupe.......................3276 lbs
5.0L V8 Convertible................3452 lbs
Cobra Coupe .........................3354 lbs
Reactions: 98Mustang2017
Im pretty sure 200 pound wouldn't make a difference this noticeable but im begging to think something is wrong with the trany it accelerates slow and yes i watch the rpms plus it jerks shifting when the pedel is to the floor
