2000 Mustang 4.6 Problems, (supercharged)
peak-j
Girard, Ks
Been a long time since i posted, im posting for a friend that is having problems with his mustang. Here is what i can tell you about it. 2000, 4.6 supercharged. It has an SCT computer with tuner, trick flow heads, typhoon intake, 88lb. injectors, D1 procharger. The engine was just built in oklahoma city, dynoed, brought home, then he drove it a couple days and it developed a bad miss. Now it only misses after it warms up, then the engine temp starts climbing. Greatly appreciate any help on this. Thanks
I guess the car set an evap code is what ive been told recently. Correct me if im wrong, the fuel tank vent line runs to the evap canister? If the tank was not venting, could it cause it to starve for fuel, run lean and start to overheat? He is supposed to be pulling the plugs and doing a compression check like trinity said. Thanks for any help
Sent from my Motorola Electrify using Tapatalk 2
+1 on the alternator... I had a failing diode on my alternator and it would start and idle fine, but after driving for a few minutes would be down on power, develop a bad miss, and wouldn't accelerate (headlights would also dim). Turned out to be a bad alternator and with a new one it ran like a champ :nice:
Real easy way to tell is whether or not the electrical components start to die off when this happens (headlights, stereo, etc). If they are still operating fine, then it most certainly isn't the alternator.
