2000 mustang srs air bag ?
gts440
I bought a 2000 mustang only to discover that the air bags had been deployed after I replaced the bulb. It has a code 19. Will the air bags & control module from a 1998 mustang work? Can I just reset my module myself? Or send mine off to be reset? Thanks, gts
LFC 19 says to "install new RCM".
An air bag module from a 98 will NOT work in a 99-04. The electrical pin out is completely different.
Information on how to access the cluster diagnostic mode.
Diagnostic Mode - Ford Mustang Forums
Restraints Control Module (RCM) Diagnostic Trouble Code (DTC) Priority Table DTC a LFC b LFC Priority Description Action To Take
— — 1 The Air Bag Indicator is Illuminated Continuously — RCM Disconnected, Inoperative, or Lost/Low Ignition Feed Go To Pinpoint Test A .
B1342 24 2 RCM Is Faulted INSTALL a new RCM.
B1231 19 3 RCM Crash Data Memory Full INSTALL a new RCM.
B1921 21 4 RCM Bracket Ground Resistance High Go To Pinpoint Test B .
C1414 29 5 Incorrect Vehicle Identification Code Go To Pinpoint Test C .
B1887 15 6 Driver Air Bag Circuit Shorted to Ground Go To Pinpoint Test D .
B1916 15 7 Driver Air Bag Circuit Shorted to Battery or Ignition Go To Pinpoint Test E .
B1888 16 8 Passenger Air Bag Circuit Shorted to Ground Go To Pinpoint Test F .
B1925 16 9 Passenger Air Bag Circuit Shorted to Battery or Ignition Go To Pinpoint Test G .
B1932 32 10 Driver Air Bag Circuit Resistance High Go To Pinpoint Test H .
B1933 33 11 Passenger Air Bag Circuit Resistance High Go To Pinpoint Test I .
B1934 34 12 Driver Air Bag Circuit Resistance Low Go To Pinpoint Test J .
B1935 35 13 Passenger Air Bag Circuit Resistance Low Go To Pinpoint Test K .
B1892 — 17 Air Bag Tone Warning Indicator Circuit Shorted to Ground or Open Go To Pinpoint Test L .
B1891 — 18 Air Bag Tone Warning Indicator Circuit Shorted to Battery or Ignition Go To Pinpoint Test M .
B1869 Tone c 19 Air Bag Indicator Inoperative Go To Pinpoint Test N .
B1870 Tone c 20 Air Bag Indicator Shorted to Battery Go To Pinpoint Test O .
B2477 Continuous — Module Configuration Error INSTALL a new RCM
— — — No Communication with the Restraints Control Module Go To Pinpoint Test P .
a DTC: Diagnostic Trouble Code, retrieved using a scan tool.
b LFC: Lamp fault code, flashed on air bag indicator.
c Tone will sound only if additional DTCs are present.
The wiring diagrams for the 98 MY show crash sensors. The wiring diagrams for the 2000 MY do not. I did find this reference in the 2000 workshop manual.
>>from Ford service manual:
The SRS contains two sensors which are integral to the RCM. The RCM is mounted on the center tunnel under the instrument panel.
This leads me to conclude that the sensors are contained within the RCM for the 99-04 MY.
As for your question about a 98 air bag fitting a 2000. IDK. However do have a suggestion. Google search on "replacement air bags". Contact one of the several sources that come right to the top of the list and ask them.
how do i remove the console?
I have my new rcm & have removed the cover with shifter upper boot & the two screws now visible. But the console must be bolted somewhere else? Is it bolted under the compartment? If so how do i remove the compartment? Thanks, gts
yes the air bags off a 98 will fit in the steering wheel , i installed the pasinger side but the connetors were diffrent , i had to cut a tab off the car connector and it fit well . now getting code 35 , i see the list above , can anyone give more info, and i also have abs light on are thay related . need info becaues taking it in to the dealers to reprogram don't want the to sell me more then i need or be tricked
