Hmm.. I'm also looking for a new clutch kit. I just bought a used T5 trans for my 96 since mine is almost toasted. I've been needing a new TOB over the years because of the noise, and the pedal has consistently become stiff and I had to lube up the TOB by spraying grease in there. It's not acceptable now because the car shudders and vibrates too much when I slowly let off the clutch to engage what little gears I have left.
What's wrong with the RAM clutch TOB? It should be as good as stock I would think, For a 3.8 with 190HP... you don't need no stage 3 spec clutch parts, not for daily driving. Tho only think I dont like about the RAM clutch kits.. is that it appears they dont come with a pilot bearing. Need that...
