- Jan 2, 2008
- 4
- 0
- 0
Starting a couple of weeks ago the temperature would gradually rise when going down the road & the heat would stop working also. But it would always jump back down to the correct temp and then the heat would start working again.
I jumped to the conclusion that it was the thermastat. So i replaced it with a stock 190 degree thermastat from the parts store.
Still the problem occured.
So i replaced the water pump.
Note: When i replaced the water pump their was no signs of wear to the pump nor signs of fluid leaking from the weap holes. (So i probably replaced something that wasn't bad to start off with)
The water in the car is also staying at a constant level. NO LEAKING AT ALL.
The problem still occured. (Overheating & No Heat)
When i drained the coolant it was like a light brown. But that was the frist time that i actually changed the coolant in the car since i got it back in 2004.
Could it be a HEAD GASKET failure.
2001 Ford Mustang
3.8 Liter V.6
Stock
148,056 miles
2001 Ford Mustang
3.8 Liter V.6
Stock
148,056 miles
