2001 gt wire diagram
bboylobo
130
Lancaster PA
I just purchased an alarm system and remote start combo for my 01 GT. I was wondering if anyone could shoot me a link to some relevant wire diagrams i will need to install this. the alarm system is a 100 dollar system off ebay that is 2 way with a bunch of wires that need to be spliced. Any relevant diagrams would be awsome. i plan on doing it myself to save money and i have alot of knowledge on electronics i just need a map. thanks alot guys and gals:D
2001 FORD
MUSTANG 2DR COUPE
RADIO_MEMORY GRN/YEL
RADIO_SWITCHED YEL/BLK
RADIO_GROUND BLK/GRN -
RADIO_ILLUMINATION LT.BLU/RED
FRONT_SPEAKER_SIZE 5 X 7'
FRONT_SPEAKER_LOCATION FRONT DOORS
FRONT_RIGHT_SPEAKER_POSITIVE WHT/LT.GRN
FRONT_RIGHT_SPEAKER_NEGATIVE NA
FRONT_LEFT_SPEAKER_POSITIVE ORG/LT.GRN
FRONT_LEFT_SPEAKER_NEGATIVE LT.BLU/WHT
REAR_SPEAKER_SIZE 5 X 7'
RIGHT_REAR_SPEAKER_POSITIVE ORG/RED
RIGHT_REAR_SPEAKER_NEGATIVE BRN/PNK
REAR_LEFT_SPEAKER_POSITIVE GRY/LT.BLU
REAR_LEFT_SPEAKER_NEGATIVE TAN/YEL
POWER_ANTENNA_TRIGGER AMP=BLU
Security Information
STARTER WHT/PNK +
START_LOCATION IGNITION SWITCH HARNESS
TACH_WIRE LT.GRN/WHT
TACH_LOCATION POWER CONTROL MOD BEHIND RT.KICK
IGNITION_WIRE RED/LT.GRN
IGNITION_LOCATION IGNITION SWITCH HARNESS
IGN_2_WIRE GRY/YEL +
IGN_2_LOCATION IGNITION SWITCH HARNESS
ACCESSORY_WIRE GRY/YEL +
ACCESSORY_LOCATION IGNITION SWITCH HARNESS
NEUTRAL_SAFE_WIRE WHT/PNK
NEUTRAL_SAFE_LOCATION IGNITION HARNESS
BRAKE_SW RED/GRN (+)
BRAKE_LOCATION AT BRAKE SWITCH
SPEED_SENSE WHT/ORG
SPEED_LOCATION PIN 68 AT PCM RT. KICK PANEL
WINDOW_UP LF:WHT/BLK
WINDOW_UP_LOCATION RF:WHT/YEL LR:GRY/ORG RR:RED/BL
WINDOW_DOWN LF:YEL
WINDOW_DOWN_LOCATION RF:TAN/LT.BLU LR:YEL/BLU RR:YEL/BL
TRUNK_WIRE VIO/YEL (+)
TRUNK_LOCATION AT SWITCH OR DRIV KICK PANEL
HEADLIGHTS YEL/RED (+)
HEAD_LOCATION AT LIGHT SWITCH
FACTORY_ALARM DK.GRN/VIO(-)
FACTORY_LOCATION KEYLESS MODULE
TRUNK_SWITCH_WIRE
more info
Make: Ford
Model: Mustang
Year: 2002-04
Alarm
Constant 12 volts YELLOW (3) GRN/VIO (2) IGNITION SWITCH HARNESS
Ignition 12 volts RED/LIGHT GREEN IGNITION SWITCH HARNESS
Starter WHITE/PINK IGNITION SWITCH HARNESS
Dome Light YEL/BLK(DR) GY/RD(PS) AT GEM MODULE * SEE TECH NOTES **
Trunk Pin Switch BROWN/WHITE (-) AT LIGHT IN TRUNK OR GEM MODULE *
Parking Lamp BROWN (+) AT HEADLIGHT SWITCH OR GEM MODULE *
Power Lock LIGHT GREEN PIN 20 OF A BK 20 PIN CONN AT *
Power Unlock VIOLET PIN 18 OF A BK 20 PIN CONN AT * #202
* Generic Electronic Module Is Located Behind Driver Dash Above Brake Pedal. #202 - See Positive Pulse Door Lock Diagram
Remote Start
Tach Signal ORANGE/YELLOW AT POWERTRAIN CONTROL MODULE * #239
Ignition #2 GRAY/YELLOW (2) IGNITION SWITCH HARNESS **
Ignition #3 RED/BLACK IGNITION SWITCH HARNESS #235
Accessory BLACK/LT GREEN IGNITION SWITCH HARNESS ***
Neutral Safety NOT GROUNDING TYPE - OEM SWITCH OPENS STARTER CIRCUIT
Brake Light RED/L GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light BLACK/PINK (+) AT SWITCH ON TRANSMISSION
Rear Window Defrost BLACK/YELLOW (+) AT REAR WINDOW DEFOGGER SWITCH
* Powertrain Control Module Is Located In Passenger Kick Panel. ** Two GRAY/YELLOW Wires Present At The Ignition Switch Are The Same Circuit. #235 - See Powering Additional Ignitions Diagram. #239 - See Immobilizer By-Pass Diagram. *** Refer To TECH NOTES For Additional Information On Ignition Switch Layout. OEM Keyless Ign. Interrupt: Not possible
Ignition Switch Layout: Ignition #1 - RED/LIGHT GREEN.......Powers PCM (Primary Ignition). Ignition #2 - GRAY/YELLOW (2).......Powers Blower Motor. * Ignition #3 - RED/BLACK.............Powers Airbag Monitor. Ignition #4 - BLACK/L GREEN.........Powers Heat/Ac Controls. * Two GRAY/YELLOW Wires Present At The Ignition Switch Are The Same Circuit. **Dome Light:Ford's G.E.M. Will Drop A Low Signal Across The Dome Light And In Most Cases Cause A False Trigger. To Eliminate This Cut the Door Pin Trigger Wires At The G.E.M. And Insert A One-Amp Diode With Band Side Facing Doors.Make Your Isolated Connection On The Door Pin Side. The GEM (Generic Electronic Module) Is Behind The Dash Above The Brake Pedal.
