- Sep 8, 2007
- 3
- 0
- 0
I am writting this in hopes someone could shed some light on me with a problem I am having.
I installed a 2003 Mustang motor in my 97 T-Bird. Everyting was pretty straight forward on this swap. However, when the motor warms up I get a very noticeable valve rap and when in gear at idle the oil pressure light comes on. I am using 5w-20 as recommeneded and motor has 60,000 miles on it.
I bought a mechanical guage and hooked it up to the drain plug next to the oil filter.
600 rpm - no reading
1500 rpm - 7 psi
2000 rpm - 12 psi
2600 rpm - 26 psi
4000 rpm - 37psi
Redline - 50psi
These readings were takin in Neutral. I am thinking that I have a bad pump. The guy who sold the motor to me thought the throwout bearing was the culprit to this valvetrain noise. I am thinking there was more than one problem now.
-Mike-
1500 rpm - 7 psi
2000 rpm - 12 psi
2600 rpm - 26 psi
4000 rpm - 37psi
Redline - 50psi
-Mike-
