  • SVT Tech Forum
2003 Cobra Tremec T-56 Swap Into 2001 Cobra
  • Thread starter Thread starter TheHolyCobra
  • Start date Start date Sep 26, 2004
TheHolyCobra
Wooster, Ohio
Sep 26, 2004
  • Sep 26, 2004
I found a local 03 Cobra that is swapping his T-56 Tremec for a TKO 600 cause he is goin up into the very high hp numbers. I was wondering if any of you guys knew what I would need to swap the stock tranny in a 2001 Cobra (I dont know if it is a T-3650 Tremec or a T-45 Tremec) to the T-56 outta the 03 Cobra? I know I will prob need a new driveshaft, cross member, and different wiring, but I do not know what I need exactly. If someone could tell me or point me in the right direction to where I can find the price of this operation and the parts I need, that would be awesome!
bigpapa
Banned
Aug 3, 2004
34
Columbus, OH
Sep 30, 2004
  • Sep 30, 2004
shorten drive shaft. can buy a new cross member or modify yours to fit which is REALLY easy. Wiring will reach for the most part. That's about it. Pretty easy.
DirtySanchez
331
Atlanta, GA
Sep 30, 2004
  • Sep 30, 2004
http://www.ddperformance.com
Note that a T-56 swap will make your car significantly slower though, unless you're putting in gears and/or a blower at the same time. 1st and 2nd gear are much taller. Here's a comparision chart: http://www.svtoa-atlanta.org/cgi-bin/trans.cgi
TheHolyCobra
Wooster, Ohio
Oct 3, 2004
  • Oct 3, 2004
Thanks guys......now here is the brain buster that i forgot to add......
If I do get a Viper T-56 installed, how would i calibrate it if i installed 4.10 gears in the rear end? I know you can calibrate stock tranny'd mustangs with hypertech power programmers but how would i calibrate the speedo with the Viper tranny? Would you use speedo gears? If so, what kind/color?
C
Cobra01Vert
39
  • Oct 6, 2004
cant use gears as you have an electric speedo.
M
2001 cobra ignition timing off
  • Mike3
  • Jul 13, 2026
  • SVT Tech Forum
SVT Tech Forum Aug 2, 2026
Mike3
M
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
  • AeroCoupe
  • Aug 2, 2026
AeroCoupe
t45 transmission How far does the clutch fork needs to travel to fully engage/disengage
  • SethG
  • Apr 28, 2025
  • Other Auto Tech
Other Auto Tech Apr 30, 2025
Cobra 8.8 differential rebuild shop question
  • Sestemybe
  • Aug 5, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 15, 2025
baileygruwell
  • SVT Tech Forum
