2003 GT steering shaft seperation
Funyuns
I have a 2003 ford mustang and just experienced a problem where the steering went completely out after investigation I noticed that the male and female tubing of the steering shaft had seperateded under dash before going through the firewall. I looked under the car and see no signs where the rack and pinion had moved nor has my steering wheel placement. Looking at break down drawings of the shaft assembly this looks like just a slip fit then bolt into the rack. It almost seems as the whole thing is to short. Is there a set screw or pin I am not seeing to lock these joints together? I also checked the Yag joint and seems to be fine. Was there ever a recall on this set up cause it seems like a recipe for disaster.
