- Jun 3, 2002
- 48
- 0
- 0
So, I went to Ford a couple of weeks ago to get a PCV valve to try and fix the check engine light. I'm at 20K miles, so i figured it was due anyways. Ford looked up my VIN number and told me I had a REGULAR PCV valve, not the electric heated one.
Well, last night i finally got a chance to go put it in... Get in there, and this is what I find.
#1 - There is a plug going into this one, which obviously leads me to believe it HAS to be the electric heated one.
#2 - The opening on the hole leading into the valve cover is about double the size of this regular one that I bought.
My question, is THIS really an Electric Heated PCV valve? I looked it up online everywhere, and the only thing close i could find is that 2004 Mach1's have an Electric heated pcv.
And how do i get this sucker out? Usually the pcv valves just pull right out, but this one has some kind of clips on it i think, but it doesnt come out at all..?
(Background info, P2197 code came up... its either a bad o2 sensor, a vacuum leak, or an exhaust leak)
Thanks for ANY help guys! This has been pissing me off so bad recently, i've never had problems with changing a PCV valve on any of my cars till now.
