2004 Mustang GT Supercharged
jauch
2004 Black Mustang GT Supercharged - $14K
Crazy Fast and ohh does it rumble. $15k-$20k in Modifications
650+ HP Boosted Beast, Motor recently rebuilt with around 500 miles on motor and clutch. If you want more info, just ask.
4.6 block bored .30 over
Forged Crank
Forged MANLY 18cc Dished Pistons
Forged MANLY H Rods
Clevite bearings
Childs and ackerly Rings
ARP Bolts through out motor
MMR High volume oil pump
PI Patriot Stage 2 Heads- ported and polished with larger valves
Cobra cams
Trick Flow Intake manifold Plenum
75 mm bbk throttle body
42 lb injectors
80mm MAF
Vortech S-Trim supercharger 14lbs of boost
AIS Stage 1, rear trunk mount water / methanol injection, duel nozzles
Twin high volume Cobra fuel pumps
Canister fuel filter on frame rail
BBK ceramic coated headers
Magnaflow stainless steel exaust off road x-pip
Flowmaster mufflers
SPEC 3+ clutch
SPEC billet flywheel
Tockico shocks
Eibach pro kit
Maximum Motorsports caster / camber kit
Subframe connectors
Steeda Triax shifter
3.73 gears
Detroit Locker
31 spline Moser axles
Aluminum drive shaft
ZR FRPP 500 style Black - 10x8 front wheels, 18x10.5 rear wheels
VIS Racing Sports Carbon Fiber 4" cowl hood
Sylvania Silver star headlights
Tinted windows
Bullitt pedals
Pro-Com Monster Phantom Tach / shift light
Steeda adjustable cluch cable and quadrant
Mobil 1 Synthetic oil
Innovate Wide band sensor and controller
SCT Power Programmer
