2005 Mustang Gt Hesitation Solved !
foxsetup
Hi everyone,
First of all sorry for the bad grammar , I speak french i am from Montréal , Canada.
I've been chasing a bad hesitation with my 2005 mustang gt since LAST SUMMER.I just found out what was the cause of it. If i can help someone with this so you don't have to loose your mind like me i will be more that pleased.
Nothing more simple than a good old vacuum leak...
I knew i had a vacuum leak somewhere but i could not find it because it was no where near the intake.
If you have a procharger with the Proflow bypass valve ( the black one ) PLEASE make a smoke test on it.
The diaphragm Inside of it can go bad and create a really bad leak.
The symptoms were :
LTFT were going high at idle
Intake back fire at low load , low rpm.
weird shifts points.
If you have any of these symptoms and don't know what it is. Make sure to check for vacuum leaks.
