Car only has 13k on it, just recently (about 500mi ago) did the CAI and Bama tune along with Ford Stingers, what a difference, like driving a new car. A couple days ago we took it out, put it away in the garage and everything was fine. Next morning I came downstairs and heard a high pitch squeal coming from the garage, opened the door and found the fog lamps on, check the switch and it was off, only way to turn the lights off was to remove the relay in the fuse box, which was vibrating and making the noise I was hearing.
Swapped the noisie relay with another one and it did the same thing, this morning replaced the dashboard switch with a new one and got the same results, I have tried removing the power from the fuse box as well hoping it would reset it, same result. (the noisie relay works fine in other slots).
Would appreciate any thoughts you guys have, it's beyond frustrating at this point.
Is there any chance that something was corrupted in the download that could possibly cause this, I don't see how that can be but that's why I'm here asking for help.
Thanks in advance!
Thanks in advance!
