2006 GT low beam headlight issue
jozo1015
i'm having an issue with the passenger side low beam headlight going out. the high beams on BOTH sides work great and the driving lights work fine, but the low beam on the just the passenger side will turn on for about 10 seconds when i first turn the lights on and then will go out. if i turn the lights off and then back on again, the passenger side low beam will come on for 10 secs and then turn off again. i've tried new bulbs in just the passenger side and then tried new bulbs on BOTH side and the problem remains. tried changing the plug on passenger side and didn't help the problem. i've seen posts about checking the smart junction box fuses and then i've also seen posts where the junction box has no fuses and that the low beams aren't controlled by fuses. could it be a switch, fuse, relay etc that's causing the passenger side low beam problem? thanks for all reads and replies!!
