  • SN95 4.6L Mustang Tech
2008 3v engine swap?
  • Thread starter Thread starter rlmesq
  • Start date Start date Sep 21, 2009
R
rlmesq
  • Sep 21, 2009
I have a blown head gasket on my 2002 GT and am considering a swap for a low mileage 2008 3v motor.
Anybody know what would be involved, parts-wise? The motor would come with all stock electronics. Will my stock TR3650 hook up, or am I looking at a transmission swap, too?
Thanks!
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Sep 22, 2009
  • Sep 22, 2009
logan performance makes a swap kit for it so it will bolt and plug right in..
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
Sep 22, 2009
  • Sep 22, 2009
you must run cam phasers as well to lock out the vct. other than that. with the logan kit its plug and play, well and you need a new intake pipe.
paultippit
Houston Texas
Oct 11, 2009
  • Oct 11, 2009
rlmesq
How is this going? I blew a head gasket in my 03 Mach 1 and considered doing the same thing.
03 Mustang gT
103
seaford, New york
Oct 11, 2009
  • Oct 11, 2009
why would you want to swap a 3v into your mach? seem like a downgrade to me?
paultippit
Houston Texas
Oct 11, 2009
  • Oct 11, 2009
It might seem like it .. but the 24v engines actually put out as much if not more HP stock than my 32v. The power adders are pretty cheap and variable camshaft timing is very appealing.
I am having some problems with compression on the 5-8 cylinders and have been trying to evaluate the cheapest way to fix it. Replacing might be the cheapest solution. When I was looking at prices for 3v vs 4v engines... the 3v were cheaper.
Just pulled the exhaust and dropped the transmission. Engine comes out next weekend.
VEE EIGHT
85
Texas
Oct 12, 2009
  • Oct 12, 2009
Site?
Mileshigh
25
Raleigh
Oct 12, 2009
  • Oct 12, 2009
via google
Logan Motorsports - SCT Tuning
and here a 5.0 article on it
S197 Mustang Intake Manifold - Logan Motorsports Sheetmetal Three-Valve Intake - 5.0 Mustang & Super Fords Magazine
Stark77
501
Tallahassee, FL
Oct 12, 2009
  • Oct 12, 2009
3v is a good idea - upgrading the camshafts on a 4v motor costs about $1400 bucks, just for the sticks. 3v Mods are cheaper and more widely available than for 4v.
trinity_gt
3,125
81
99
Canada
Oct 12, 2009
#10
  • Oct 12, 2009
  • #10
The 3V mods are pretty impressive but I'd still rather have a 4V setup, especially if you've got a manual box and thus the steel crank, 8-bolt flywheel and 7000RPM to play with. And those mods making 315HP from the factory already basically have FRPP exhaust, CAI and agressive tunes in place. That sort of stuff on a 4V should, I would think, eclipse a 3V in terms of output.
But it's not as if the VVT on the Mustangs is used to enhance power delivery, especially since there's a single cam on each side and valve timing changes made to, say, the intake affect the exhaust as well. It's an emissions thing, not a power thing.
If an entire bank is hurt I'd suspect something in the valvetrain or cam drive on that side. I think it'd be cheaper to source a rebuilt head (for example) for a 4V than swap in an entire 3V engine, intake, harness and so on.
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
