Mustang Forums at StangNet
Search
By:
By:
Advanced…
What's new
Search
By:
By:
Advanced…
More options
Toggle width
Install the app
  • 2005 - 2014 Specific V6 Tech
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
2008 Mustang Fuel Pump Grounding Issuess
  • Thread starter Thread starter tx2la
  • Start date Start date Mar 30, 2017
T
tx2la
  • Mar 30, 2017
I tested fuel pump worked fine. the fuel filter is disconnected to check flow. I say it is a grounding issues because I cut black wire going to the fp. put wire on the pump side to a bolt to ground pump ran. I put wires back together fp will not run with filter still out. any ideas?
D
Negative Grounds for 2008 4.0L
  • deadbeat
  • May 13, 2026
2005 - 2014 Specific V6 Tech May 13, 2026
deadbeat
D
Creomod
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
Fox 5.0 Mustang Tech Wednesday at 8:31 PM
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Ryu
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 5, 2026
Ryu
Ryu
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2026
Mhaley2006
M
  • Dark Mode
  • Contact us
  • Terms and rules
  • Privacy policy
  • Help
  • RSS
Community platform by XenForo® © 2010-2026 XenForo Ltd. | Style by ThemeHouse
Top Bottom
Back
Forums
