Hey guys,
I am encountering an issue with the notorious P0345/P0349 camshaft position sensor.
So far I have:
Replaced the sensor
Rewired the connector
Replaced the alternator
The DTC came back just as it was prior.
I filled a troubleshooting method which had me check the ground wire in the connector.
Bank 1 shows a solid ground, bank 2 does not.
Bank 2 is where the issue is...
As far as I know, the engine runs fine, idles fine, and appears like all is well besides the DTC.
I wanted to check the wiring coming from the PCM but I cannot find where this sensor connects.
What should I do next?
So far I have:
Replaced the sensor
