- Oct 9, 2003
- 968
- 1
- 17
I'm trying to nail down what injectors to order tomorrow for my AFR165, FTI, and Performer setup. Most people use 24's, but I've seen a few use 30's. I'd like to keep it as small as possible to help with idle quality, but don't want the duty cycle to be too high on WOT. Accel makes some 26 lbs-hr injectors, maybe these would be ideal.
According to the formula to determine the injector size needed based on HP level, the 24's seem too small to maintain less than a safe 80% duty cycle. Assuming the engine can produce 350FWHP, has a bsfc of .5, and not to exceed 80% duty cycle, the injector required would be a 27.3 lbs-hr.
Injector = (HP x bsfc)/Nc
Nc = number of cylinders
Injector = lbs-hr rating of injector
Dc = duty cycle
bsfc = brake specific fuel consumption (fuel efficiency)
To produce 350HP, a 24 lbs-hr injector would be pushed to about 91%. I realize that it will work, but it's shorting the life of the injector and risking burning it out. Of course, this is all math, and not real world use.
Has anyone logged duty cycles with a tweecer (or similar) to find out what they are with any of these injector sizes?
Even if you haven't, what is your opinion?
Thanks,
Rick
Dc = duty cycle
Thanks,
Rick
. I didn't create my own calibration from stock, I started with one from someone else who has a similar combo.
