24 Lb Injectors
No offense, but I suggest you change professions with that kind of advice. There are hundreds if not thousands of guys running 19's and around 300 hp. 24's can easily support 325...
Jrichker posted this several times
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP
385 HP x .85 = 326 HP
480 HP x .85 = 408 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
If you don't know who he is, Decipha is a damn tuning wizard. There are ways to cheat undersized injectors, and people do it every day, but there are a lot of corners that people cut with these cars across the board.
Plus I think Decipha is talking rear wheel and you're talking crank.
Reactions: f8tlfiveo
If he's talking RWHP then yes, he is correct. Appreciate the clarification and again, no offense was being made and no assumptions either.
Tell ya what I'll do. I'll swap the heads (new TFS springs included) intake, TB and switch to the 1.7 roller rocker arms. I'll put it all back together with the 19lb injectors, give the setup some time to adjust then take it in for a dyno pull.
We'll see what the tuners data says and take it from there.
Merry Christmas everyone. Be safe out there whatever you're doing.
I'm getting to like the wideband O2 idea. I'm the type that likes a hands on approach. The ability to see what's happening and make periodic adjustments to A/F ratio is something I'm interested in.
What are the recommended kits?
im a fan of the fast dual wideband set up. that way you can watch each bank
That sounds more expensive. Btw, how would you address each bank individually if they were unbalanced.
What is an entry level type kit that is viable and more on the affordable side?
I mean, I expect to make various changes to setup over time. So being able to see what's going on and adjust is the idea.
Stuff like- ok, time to change injectors, or raise/lower fuel pressure.
