I just swapped some 24lb injectors and a Pro-M mass air meter onto my car. Is there any kind of adjusting that you have to do to the fuel pressure when you install these? It seems like you would have to turn up the fuel pressure a little bit to accomodate the larger injectors.
The reason I ask is after the install, my car runs pretty lousy once it is all warmed up, a lot worse than before the injectors. (lean/rich problem?)
Maybe it's my fuel pump? any input would be great.
Thanks
Thanks
