24s or 30s
5spd GT said:
It is about 9.7:1 if I recall correctly.
On pump gas right? humm... I think I will try and bump my base timing up a couple * also are you running factory temp range on your plugs? if not,what range-1 colder, 2 colder? thanks
Well for my AFR heads, I use Autolite 3924's...I believe 1 degree cooler than a stock plug. I'm not running stock style plugs though.
I have them gapped at .045. I could probably go "larger"...but it runs fine where it is at.
Oh yeah, on 93 octane or 91 octane. It was my daily driver for 3 years until a couple months ago...it seen every situation possible...I had no problems on pump gas. I never modified the fuel...just straight from the pump:nice:
