25-35 oil pres.----how much more time?
NKau
1,346
Jefferson, WI
25-35 lbs. oil pres.----how much more time?
The engine in my car has already been rebuilt once in it's 98K mile life (by previous owner) and the oil pressure pressure has me worried. On cold startup it will hover in the 45-50 psi range (good electrical autometer guage), but after it warms up, and regardless of how hard it's driven, the pressure will not crest 35 psi, but does not dip below 20-25 psi at idle. I know it's pretty hard to predict how much time this engine has left, but I'm more or less curious exactly how bad an idea it is to be running something like this at the track? I've been thinking about bringing it down to Florida where I work over winter to do some light wrenching on it/have fun with it, but am kind of worried about ending the shortblock without having a place to work on it. Any opinions?
I normally run some 10w30 dino oil in it, but have since put in 10w40 and not really noticed a difference.
The whole situation kind of sucks, because I bought the car thinking I would be able to do the h/c/i on the existing shortblock. Guess that's what I get for trusting the factory guage when I purchased the car.........
I'm probably just going to go with my gut and your advice and just run it. Thanks.
2002BLGT said:
previous rebuilder probably didnt put cam bearings in it , thats where the oil pressure is getting lost , dont worry about it till its under 10 LOL
I was wondering the same thing; figured maybed a couple of the cam bearings got nicked when the cam was installed, or just were never replaced. I'm guessing those can't be replaced without tearing down the whole engine either.........
crunchie12268 said:
I think the harder part would be getting the bearings out, then it wouldn't be that hard to put new ones in......sure would take some time though. Might as well just rebuild it. I wouldn't worry about it until it us really low.
to put bearings in and get them out you have to take the block to a machinist... you can't just take them out
It's pretty hard to predict. My SCCA racer a few years back (Toyota Corolla) suffered from low pressure when the oil temps would climb. In July/Aug. in Houston, not uncommon to see 250-300F oil temps during 2 hr. enduros. When temps would get high, oil pressure would drop. I was alarmed the first time it happened. Pressure dropped into the 28-35 psi range. The engine would literally spend an hour at a time between 4500-7000 rpm with a 5 minute pitstop, and then another hour at the same revs. Nothing happened at all. I finally got used to it. The car lasted 4 more (about 30 races) seasons, and then I sold it to a fellow racer. The engine didn't seem to care.
I don't share the story to try and give you comfort that it will be ok - but just to let you know you'll get folks who'll tell you theirs blew up the next day, and then there's folks like me where the engine saw extreme abuse, and didn't seem to care that it had only 35 psi at 7000 rpm. Go figure.
