  • SN95 4.6L Mustang Tech
281 to a 302 stroker
  • Thread starter Thread starter mustanggt3685
  • Start date Start date Nov 17, 2005
First Prev 2 of 2
blackfang
1,290
Richmond, Va
Dec 29, 2005
#21
  • Dec 29, 2005
  • #21
Our 281's have a similar stroke as a 351 so stroking it more isnt the optimal way to go. Your increasing the instability of the pistons at a faster speed. Big bore is where you will make more power and safer. You unshroud the valves by doing this.
I think you can big bore the 2V block to 3.73" with darton sleeves. not 100% sure but the aluminum block is the way to go and some have gotten them for under 400 shipped.
T
TGJ
1,049
#22
  • Dec 29, 2005
  • #22
Mark8Denny said:
well I need a rebuild , my stock long block made 355 RWHP and 325 RWTQ till it snapped the rod mid beam. expected for 140,000 mile MK8 motor , but anyway I did the math to check the changes in the rod ratio. I also race other brands and my other engines with great torque bands have higher rod ratios and I am a believer in that idea.(a 4.6 stroker just lowers it from stock). I am already using a 3.33 pulley on a S trim Vortech and think I may spend the extra couple hundo's on some other parts I would have to buy anyway. My Mark comes out of the hole like a turbo car and that would save the rear axles anyway, If I wanted to dump the clutch I would have kept my 96 Cobra (too small inside). Thanks !!
You have the ideal block for a Big-Bore. All Mark VIIIs were equipped with the Teksid aluminum block. The BB would be the way I would go, actually did go with my TBird.
C
Chris Olenick
#23
  • May 10, 2012
  • #23
My 97 gt was bored .030 over and than added a stroker kit to make it a 5.0 by the guy i bought it from, than i added comp cams, patriot heads with a PI manifolds and it has right now about 370 on 93. I still say upgrade some other things and buy a supercharger, they are a lot cooler cuz this was a lot of money for me.
D
darkside03gt
851
Sacramento CA
May 14, 2012
#24
  • May 14, 2012
  • #24
Dont waste your money on a stroker kit. If you do a lot of reading on the subject they really don't off a lot of extra HP due to the small cylinder bore ford cursed us with. When you add the additional cost of the kit its really not worth the money.
trinity_gt
3,125
81
99
Canada
May 14, 2012
#25
  • May 14, 2012
  • #25
A 3.800" stroke (to get 302ci with a stock bore) seems like an awful lot in the 4.6 block. How long does the rod end up being? What the rod ratio? Does the pin end up in in the ring stack? How far out of the bore is the piston drawn at BDC and how stable is it down there?
Given that these engines are really limited in bore -- the Windsor pushrod motor had a 4" bore and a measely 3" stroke -- and the fact that all the stoke in the world will not make up for the limited resultant valve size, it seems to me that all of the money and effort put into a stroker would be better spent on a supercharger setup...
Reactions: Winters98GT
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
May 14, 2012
#26
  • May 14, 2012
  • #26
+1 isn't enough
jmc01gt
60
Austin Texas
May 31, 2012
#27
  • May 31, 2012
  • #27
I'm going back and forth between a new GT 500 or building my 01, and this thread is where I have questions. What about getting the Boss Mod Block and the stroker kit for a 5.3L?
First Prev 2 of 2
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
T
Which to keep 1979 Ford Mustang or 2013 VW Jetta TDI Sedan
  • toasterboy1
  • Sep 13, 2025
  • Off-Topic Hangout
Off-Topic Hangout Sep 14, 2025
toasterboy1
T
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
