quick question...what all from a 289 is the same as the 302...bellhousing, motor mounts, cams, etc....ill be putting a 302 in a 65 mustang here pretty soon and just want a heads up on whats needed....thanks in advance guys:SNSign:
Early 289s had 5 bolt bellhousings, later 289s had 6 bold bellhousings.
289's were available with 2 different camshafts, one hydraulic flat tappet and one solid lifter flat tappet. Early 302s had a hydraulic flat tappet cam, and later model 302s had a hydraulic roller cam.
I believe all 302s, early and late model, are for 6 bolt bellhousings.
There should be no difference in motor mounts, the blocks are essentially all the same dimensionally.
