289 cam info
  • Thread starter Thread starter red68stang
  • Start date Start date Apr 16, 2011
R
red68stang
  • Apr 16, 2011
Hi, I give thanks in advance to anyone who lends help.....Im a new ford guy... always had gm stuff in the past. I have a 68 mustang with a solid but stock 289. I would like to install a bigger cam for some improved performance, but mostly for the lumpy big cam sound... any suggestions for a cam without any other head mods?....Engine is a solid 289 with a edelbrock performer intake with a edelbrock 600 cfm carb. auto trans (c4) with stock converter... 373 rear gears (appox). any thoughts?... Thanks!
G
gregski
577
Sacramento, California
Apr 16, 2011
  • Apr 16, 2011
forgive me I'm a newb, but from what I have heard, most manufacturers sell kits, so since you already have Edelbrock carb and intake why not continue down that road, at least it will ensure all is compatible, so how about their
Performer Plus off-idle to 5500 rpm Part # 2122 or the Performer RPM from 1500 to 6500 rpm Part # 7122
Just trying to help, if these will not work, then can someone learn us why it would not work or be a good idea?
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Apr 16, 2011
  • Apr 16, 2011
The performer has a smooth idle as it only has 204 degrees of intake duration. The performer RPM has a 224 degree intake duration so that should do it.
woodsnake
1,352
15
69
Hicksville, NY
Apr 16, 2011
  • Apr 16, 2011
A lumpy big cam sound is cool, but you will also want the performance from it, won't you? A 3.73 is a good gear for a decent cam, I think you could use a performer RPM range cam (.496/.520) with those gears, and really enjoy it! That will require an adjustable valve train, and custom push rods though. But if you only want noise, and not a quick car, I've heard the "thumper" line of cams are good for that...
31-601-5 - Hydraulic Flat Tappet Camshaft
Info on the product line...
http://www.compcams.com/Thumpr/index.html
2+2GT
3,333
10
79
Southeastern Pennsylvania
Apr 16, 2011
  • Apr 16, 2011
A guy near here took his "solid" 67 289 2V down, installed the Edelbrock Performer RPM intake and 600 cfm carb, stock distributor recurved to BOSS 302 specs, iron 67 heads port-matched and cleared of smog bumps for decent breathing, and a C9OZ-6250-C hydraulic version of the 289HP cam. When assembled, it turned 323 hp on the dyno. Pretty good numbers for a low-buck build, especially since he did the heads himself. More info on that here:
289/302 Cylinder Head Port Matching
Edster
500
League City, Texas
Apr 16, 2011
  • Apr 16, 2011
The Performer RPM cam has a real nice lope to its idle. I would do as woodsnake suggests and use that cam. I'm happy w/ mine. I wish I had 373s all i got is 3:1s Oh BTW I would get a performer RPM intake to better match the cam too. Something to think about down the road.
G
gregski
577
Apr 16, 2011
  • Apr 16, 2011
keeping the stock springs, or should the valve springs be replaced too?
rbohm
6,698
550
204
tucson,az
Apr 16, 2011
  • Apr 16, 2011
unless the springs are rated at the proper pressure and lift capacity, always change the springs when changing cams.
G
gregski
577
Apr 16, 2011
  • Apr 16, 2011
That's what I thought, but see his initial post says "any suggestions for a cam without any other head mods?" not sure how you can go lumpier and not do the springs, that's all
iskwezm
4,159
20
79
Rowland Heights,California
Apr 16, 2011
#10
  • Apr 16, 2011
  • #10
I had that cam and i liked it alot.You will need better springs, the stocks will not hadle the lift of that cam and float too early losing rpm.
D
First post 289 rebuild question!
  • Ddyer2868
  • Nov 24, 2025
Classic Mustang Specific Tech Dec 5, 2025
rednotch
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
F
289 to 302 Engine
  • Fri Guy
  • Feb 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 13, 2025
Fri Guy
F
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
