289 Flywheel Installation
  • Thread starter Thread starter Blu-Steel
  • Start date Start date Oct 25, 2007
Blu-Steel
92
Waynesville, MO
Oct 25, 2007
  • Oct 25, 2007
Does it matter how the flywheel is bolted to the crank in relation to the harmonic balancer? I ask because I know the balancer and flywheel are 28 oz imbalance, and I noticed the flywheel has an offset bulk in the casting, so that got me to thinking it might throw off the balance if I mount it wrong. It's an original flywheel that I had resurfaced and I am putting it on my newly rebuilt engine.
65fastbackresto
1,229
AR
Oct 25, 2007
  • Oct 25, 2007
It`ll only go one way
The bolt pattern is directional so to speak, the holes will only line up in one position. Rotate the flywheel till all the holes show up.
Blu-Steel
92
Waynesville, MO
Oct 26, 2007
  • Oct 26, 2007
Thanks. I didn't notice the bolt patern being different since I put it back on the way it was on the old engine I took it off of. I had a vibration in that engine and wondered if it might have been caused by the flywheel being incorrectly mounted. It looks like the old engine was remanufactured by one of those mass engine rebuilders since I have two #5 connecting rods, two #7 connecting rods and two #3 connecting rods. I bet they didn't balance the rotating assembly which caused my vibrations. I'm replacing it with a PAW engine which is balanced so I wanted to be sure I got the flywheel right. Thanks again.
D
D.Hearne
11,730
south louisiana
Oct 26, 2007
  • Oct 26, 2007
Make sure you have the right imbalance weight flywheel. There are two weights for small blocks---28 oz & 50 oz.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Oct 26, 2007
  • Oct 26, 2007
It's possible, but like D.H. said, make sure you have the right flywheel imbalance on the flywheel for the engine you have before getting a new one. I will say that so far my PAW engine is pretty nice. The crank and rods were rebuilt(and all the same numbers), but everything else was new, even the block.
BarnStang
1,260
Hagerstown, MD
Oct 27, 2007
  • Oct 27, 2007
You will need to know what imbalance the motor is that you bought. THen the harmonic balancer and the flywheel need to match that. You also need to know for sure what imbalance the flywheel and harmonic balancer are that you have. The flywheel will be easy, the cast weight will be small for 28oz early style, and large for 50oz latemodel style. Maybe someone has a couple pictures of each they could post up just in case. Size is a matter of perspective And I'm not sure how to tell on the harmonic balancer. I'll defer that to someone who knows for sure cause I don't want to guess.
You can also take your balancer and flywheel to a good machine shop and they can spin them and tell you what the imbalance is.
65ShelbyClone
4,675
38
119
Oct 27, 2007
  • Oct 27, 2007
If the flywheel and balancer are Ford parts, then the part number can also reveal what balance factor they have. A part number starting with C or D will rule out 50oz as a possibility because 50oz wasn't used until the early '80s. The counterweight mass can also be determined by looking at the back of the flywheel.
Scroll about halfway down on this:
http://www.fordmuscle.com/archives/2000/09/t5swap/index.php
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
H
1966 mustang starter and pulley troubles
  • Hotrods4ray
  • Sep 24, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 10, 2026
Realmongo
Wanting to replace my BOSS 351C Engine Harmonic Balancer - Questions about 'Balance?'
  • 69machmike
  • Oct 31, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 5, 2024
Realmongo
N
Vibration issue
  • Nicolaj
  • Apr 14, 2024
2K
Classic Mustang Specific Tech Nov 8, 2024
AeroCoupe
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
