I am new to the classic Mustang scene. I have a 66 289 coupe that developed an oil leak between the scattershield and block. Removed tranny/scattershield/clutch/flywheel and block plate. Leak seems to be from oil pan seal below rear main bearing. Was told that this engine has a split main bearing seal and the previous owner indexed this from the main bearing cap so that the halves wouldn't line up. Questions are as follows. Is this a common occurence? Can the oil pan be removed without pulling engine or can it be lowered enough to get to the gasket? Any advice? Please respond. Brian
