I am rebuilding my 68 289 and while I have the motor apart I was going to swap in a hi flow oil pump. Does any one know if I can reuse a stock size oil pan or does it need to be of larger capacity?
another reason not to run a high vol pump with a stock pan is that you run the chance of sucking the pan dry at higher rpms. stock pump is plenty good for almost all
