- Aug 5, 2001
- 54
- 0
- 6
Hey guys my t5 has a problem. I just put royal purple atf in my t5, when the tranny is cold it shifts fine. But when it warms up it grinds and it grind very bad if i try to shift at higher rpm's. Do you think i need to adjust the clutch and change the fluid to regulat dex/mec fluid? The guy i bought it from said he had put 75/90 gear fluid in it and ran it for a few hundred miles, i know that you shouldnt run gear oil so i changed it to royal purple but it shifts bad now. With the gear oil it had no problems.
all you need is ATF! of any kind synthetic or non!
