2nd gear pops sometimes???
  • Thread starter Thread starter torch93
  • Start date Start date Nov 26, 2010
torch93
143
bakersfield c.a
Nov 26, 2010
  • Nov 26, 2010
my 2nd gear pops out sometimes, but most the times pops out when i down shift... is it my syncros, fork, gear itself? its a stock t-5 ... but i also have a tremec t5z? something like that.. its the world class tranny? but same thing with second it pops out when driving BUT if i down shift it grabs n if i take off in 2nd it works find? any ideas? is it something that i can fix or take it to the mechanics? all i know to do is change clutch and tranny oil... thats about all the experiance i have on trannys
MFE92
1,094
373
124
Phoenix
Nov 26, 2010
  • Nov 26, 2010
2nd gear syncro has seen better days. If you can remove and reinstall the trans, you're proficient enough to rebuild it, IF you have a couple of extra tools and some good instruction. You'll want access to a press, you'll need some inside and outside snap ring pliers, a specific torx bit, and a dial indicator. There are instruction videos from Hanlon Racing and others, and there's a good writeup at pomoforacing.com
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Nov 28, 2010
  • Nov 28, 2010
Usually its a sign that the dog teeth on the 2nd gear and 1-2 slider have seen better days. You'll need to open to inspect, but you might need to purchase a new 2nd gear and 1-2 slider. eBay actually has decent prices on these gears from aftermarket vendors. Purchase a new blocker ring for 2nd gear and you could do the entire job for under 100 bucks if you can take a trans apart.
But while you are there, might as well purchase a complete rebuild kit and replace all the blockers and bearings.
FYI, all 85+mustang t-5 are world class. To identify what model you have, you either need the tag on the trans bell housing tom decode, or you open the trans up and read the 3-digit code off the counter gear to determine the gear set
torch93
143
bakersfield c.a
Nov 28, 2010
  • Nov 28, 2010
oh ok i was told so about the world class before i got it too ya i took it off a 1993 cobra R and it said tremec so i thought it was a good deal... the price i paid for it; i just took that one off and put his other tranny on, so pretty much for free.. is it worth rebuilding that cobra r tranny or just rebuild my stock t-5 that originally came off my 1993 gt?
torch93
143
bakersfield c.a
Nov 28, 2010
  • Nov 28, 2010
ima read up on the how to do.. and see if ill be able to accomplish the task.. if not how much u think it will run me if i buy the parts and have a shop do it?
Mustang5L5
Mod Dude
Feb 18, 2001
43,367
18,112
224
Massachusetts
Nov 28, 2010
  • Nov 28, 2010
If it says tremec on it, it's not a 1993 cobra transmission.
Tremor bought Borg Warner in 1997...so, if the t-5 says tremec on it, it was made sometime after 1997.
1993 cobra and 1993 cobra r use the same transmission, but under the Borg Warner brand name in 1993.
I don't know what your t-5 is....but its not from a 1993 cobra. Unless it's a z-spec trans, it's more than likely identical to your original 1993 trans anyway. So rebuild either
Really need the tag info off the bell housing to know what it is
torch93
143
bakersfield c.a
Nov 28, 2010
  • Nov 28, 2010
Ohhhh ok make sense... Ok cool
Drivetrain Downshifting from 3rd to 2nd issue
  • Scott_S
  • Apr 23, 2026
Fox 5.0 Mustang Tech Oct 12, 2026
limp
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
