I was comparing power / torque peaks for some cars, and it occured to me that in many ways the 260HP GT is a real oddball. For example, it makes a much bigger torque number than its power number (302 vs. 260), but at the same time its power curve is at fairly high RPM. I really do not consider it a very responsive motor below 3000 RPM, despite the big torque number. To me, the motor feels like it likes high RPM.
Now I know that the power and torque numbers use different units, and that the RPM peaks are a somewhat different issue from the power/torque tradeoff. Throttle response is its own issue, also. At the same time, though, it seems like there are some general trends that the 260HP / 2V motor defies:
Usually a motor with a power peak at 5250 RPM would not exhibit the bias toward torque that the 260HP motor does. For example, the most common version of the LS1 reaches its torque and power peaks at 4000 RPM and 5200 RPM, respectively, almost exactly like the 260HP motor. But the power peak is 310HP and the torque peak is 340LB/FT. The numbers are closer to each other (30) than the Ford's numbers are (42).
There is another issue I have with the LS1... it seems like a smaller, OHC motor should come closer to the LS1 in power, not torque. That big LS1 should excel at torque and the OHC 4.6L should (to some extent) make it up on the top end. This is the stereotype. But the exact opposite is true... the torque peak of the 260HP motor is really pretty close to the LS1 (302 vs. 340) but the power differential is greater (260 vs. 305). In a race, the GT will do a decent job keeping up off-the-line and up to 60MPH, but the Z28 will absolutely run away on the top end. This seems backwards to me.
Looking at the intake manifold of the 4.6L motor just confuses the issue further. The runners look seriously long and narrow to me... like an effort to boost low-RPM torque and throttle response was made. But the power curve is up at high RPMs... a 4000 RPM torque peak in particular seems high for a V8. In terms of real-world experience, I can feel the motor "wake up" around 4000 RPM. It seems like Ford could have gone all-out with the power / breathing ability of the engine, instead of going for a high-torque approach that no one can really feel in the seat of their pants anyway.
Overall, I think it's pretty cool that Ford can get so much specific torque out of the Modular engines as a whole. Supposedly the new 4V, naturally aspirated motors are excellent in this respect also. It points out the fact that Ford is not blowing smoke when they say that the Modulars are low-friction devices... clearly more of the power of combustion is making its way to the drivetrain than in previous designs.
I guess my questions are:
1) Do you consider the stock GT motor a "revver" or a "torquer?"
2) How do you find the throttle response of the motor?
3) What has been done with short, wide intake runners on these engines?
Also, I will propose a theory. Ford figured they may as well use that serpentine intake, with the long coiled-up runners, since the heads are a bottleneck anyway. Short, wide intake runners would have given a very slight power boost (because of the heads) and would have killed what throttle response the engine does have.
