  • 1994 - 1995 Specific Tech
3.73 gear install
  • Thread starter Thread starter rude_life
  • Start date Start date May 30, 2005
rude_life
372
  • May 30, 2005
Hey guys can you guys take a look at this page and tell me if it is good enough to use when i do my gears next weekend??
http://www.corral.net/tech/drivetrain/gears.html
Also, are there any bolts that need to be soaked in WD-40 or something similar prior to ripping everything apart?
Thanks.
JJ95GTID
1,141
Phoenix, AZ
May 30, 2005
  • May 30, 2005
You'll want to soak the driveshaft flange bolts and the ABS sensors where they are pressed into the mounting plate. Be careful removing the ABS sensors. There is one bolt that is a torx head that holds the ABS sensor on. AND the sensor is plastic so be careful using tools to get it out. I used a large adjustable wrench (cresant style) to carefully twist the sensor to work it loose.
That is a very nice write-up in the link you provided. If you don't plan on replacing any bearings then be sure to return all of the shims to EXACTLY where they came out. You can even use the same pinion shim if you have a press to remove the pinion bearing. I did this and have absolutely no problems with noisy gears. I even used the original crush collar since it was not fully collapsed.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 30, 2005
  • May 30, 2005
Another way to deal with the drive shaft bolts that sometimes can be tough to get off is to heat em up a bit......the heat softens the lock tigbt on the bolt threads.
Later
Grady
GRGT1994
1,034
  • May 30, 2005
That is a good walk through. If you want to look at some other good tips, run a search for a thread by Mo_Dingo. He has some good tips and links to other walk throughs.
I soaked the driveshaft bolts, abs sensors, and rear end cover bolts in PB Blaster. Maybe overkill, but everything came out ok for me. Well everything but the sensors, which were corroded in rock solid.
You might want to make sure you have a female torx socket in the right size. It is a fairly specialized item, and i ended up running to get one in the middle of the install. The other thing you might like to have handy is a bolt extractor socket set (sears or any big box has em). It's a set of harded steel sockets with blades on the inside. I had to use it to pull the carrier shaft retaining bolt (which I believe Ford hits with red threadlock that holds very well - so well I rounded over that bolt good).
Good luck.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 30, 2005
  • May 30, 2005
Somebody had a thread about a simple mod that allows you to do this without having to mess with the ABS sensors. Its been a while since I've seen it. You make one of the holes a little larger for the sensor to slide down in which allows you to pull the c-clip. Thats all I can remember about it.
Later
Grady
Venom351R
4,548
41
98
MAINE
May 30, 2005
  • May 30, 2005
Have fun doing the crush collar
94-302-vert
1,947
NE CT
May 30, 2005
  • May 30, 2005
Yeah Especially if you are doing this under the car yourself... It took me and my bud to tighten the pinion nut enough.
Chris
GRGT1994
1,034
  • May 30, 2005
The best way to do the crush collar (at least that I found) was to get the long arm ratchet (buy one if you don't have it, you will thank yourself for it) and set it up on the pinion nut. Then come out from under the car and pull from the passenger rear wheel well to tighten. It makes it EASY to tighten, you just lean into it. This approach works best if you have a friend. One of you can stay under the car and set up and pull the ratchet back for a full yank, and make sure its good and on the nut, also make sure the screwdriver, or whatever you are bracing the pinion flang with stays in place. From under there you can swap over to the inch pound torque wrench to measure from there too. The other guy stays in the well, and pulls.
And loosening the pinion nut was a snap too. I just loaded up the breaker bar and propped a jack under the end. About an inch of lift on the end of the breaker bar was plenty to break it loose.
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
'03 GT Fuel Pump/Pressure/Delivery Issue
  • Brodach
  • Oct 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 31, 2025
gkomo
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
