3.73 Install
300k miles? You should replace your axle bearings and seals. I agree, rebuild the traction lock. Use new carrier bolts. You should go for the better Ford install kit with the gt500 pinion bearing and crush sleeve.
LMRS sells a great kit and you get a Stangnet discount
http://www.latemodelrestoration.com/item/LRS-4210A/Mustang-88-Rear-Gear-Super-Install-Kit
If you haven't bought the gears yet, I'd suggest this kit as it is cheaper than piecing it together and are Ford gears.
http://www.latemodelrestoration.com/item/LRS-4209FRB-K/Mustang-88-373-Ratio-Rear-End-Gear-Kit
Traction Lok rebuild kit with carbon shims
http://www.latemodelrestoration.com...88-Traction-Lok-Rebuild-Kit-with-Carbon-Discs
Axle bearing kit
http://www.latemodelrestoration.com...Mustang-Rear-Axle-Repair-Bearing-And-Seal-Kit
Reactions: 2000xp8
Agreed redo the entire thing.
Also find a competent shop to do the install. Rears IMO fall under the advanced category. Screw it up and it will whine and you could ruin the entire thing.
I'll assume you are trying to do this on some type of budget considering you want to use explorer gears that are used (which i don't suggest). If you want to do gears right you can throw that budget out the window.
Axle bearing kit
How would I us the StangNet discount on LMRS. Thats a pretty good kit for a fair price.
Man. I must be screwing something up again. I searched for the name Jarrod on here and it doesn't turn up any current members...?
