  • SN95 4.6L Mustang Tech
3.73
  • Thread starter Thread starter Newbie143
  • Start date Start date May 31, 2005
Newbie143
226
  • May 31, 2005
I'm going to instal the 3.73 set on my 2004 GT 5 speed. My question is: Can i do this at any shop or by myself, or does it need to be done by a pro??
Is it just as easy as replacing stock gears with stock gears or does it need a different installation method?
thanks
ACSPONY
20+ Year Stangneter
Oct 10, 2004
711
Ohio
May 31, 2005
  • May 31, 2005
Gear installation is not usually something you install yourself, unless you've done it before. Since you really don't want to mess up gears, it's better taking them to a reputable shop to get them installed.
01SN8K
135
  • May 31, 2005
if you dont know then dont bother. it isnt worth tring if you have never shimmed a pinion and carrier before. if you can do it at a shop with someone who can help that really knows how to, that would be the easiest way to go. its a pain in the a$$ and you have one try to get it done right. wrong even by the slightest shim and you will have a rear that howls and whines.
Give Me TP
936
Republic of Texas
May 31, 2005
  • May 31, 2005
It also takes some specialized tools (dial gauge, inch-pound torque wrench, press) that not everyone has.
Ruffrider
1,018
Citrus Springs, FL
May 31, 2005
  • May 31, 2005
I wouldn't attempt it yourself. A shop will have all the special tools you'll need.
Your gonna love the gears though. I couldn't decide between 3.73s or 4.10s so I went in the middle and got 3.90s
03poontanggt
296
fresno ca
Jun 2, 2005
  • Jun 2, 2005
I just did some ford racing 3.73's and the work perfect with my n20 setup
Dark Knight GT
I can't get it up......ok that didn't sound right.
May 26, 2003
3,653
Ozark, Missouri
Jun 2, 2005
  • Jun 2, 2005
I'll agree with the other guys. If you don't know what you're doing, do not try it. Changing gears isn't like changing spark plugs. There are so many little things that have to set just right like backlash and pinion depth that if you're even a fraction of an inch off, you'll throw the whole setup off and ruin the gears. Basically put, if you don't know what you're doing, let someone who knows how to do it do it for you.
K
Digital Tuning Going heads/cam/intake. Do I need a tune?
  • karhoot
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 14, 2026
karhoot
K
D
96 get convertible-sell or part out?
  • DTCstang
  • May 17, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? May 18, 2026
nickyb
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
C
98 gt fuel pressure issues
  • chasecollier1984
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 2, 2026
chasecollier1984
C
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
