3:73's out 4:30's IN
2003MYSTANG
Tucson AZ
I was talked out of the steeper gear set and into 3:73 about a year ago. I was robbed!!!!! Live and learn and pay again. The 4:30's are the way to go with the mod motor. My tire size on the rear "315/35/17" is a little taller and led me away from the 4:10's. At 75 mph in 5th the rpm's are 2600. Right at the bottom of the power curve. 1st-4th snappy,snappy, snappy!!!!!!!!!!! :banana:
Now about that Twin Screw ???? :cool:
Glad you like it. That's alittle too much gear for me but it's all about having fun and what makes you happy.
That gear set and a twin screw would be interesting.
I have 4.30's sitting a box, but I might not put them in since I just installed 100 shot of N2o. I dont want to run out of gear but the time I get to the end of the track. Shifting to 5th at the end would probably hurt my times.
^3K @ 65 LOL, now we are getting closer to how my 66 is taching LOL, but its 3K at about 55, no O/D and 3.80s. IMO when you get up ther you loose the function of O/D and i tell you what, it IS NOT COMFORTABLE in the 66 taching 3500RPMs at about 70MPH, and with 4.30s in an auto or a 99-00 your getting darn close. But hey I guess most of you dont have a weekend worrior to drive around...the GT is your "hotrod", see my GT is my daily driver that i want to feel comfortable in, so maybe thats why i am against anything above 3.90s LOL.... BTW I know 3.80s are not very steep for a car that can turn 7500RPMs, but its going to be S/Cd and I am planning on keeping it at around 650RWHP.Thats why those gears are in, that and mainly because theres no O/D for right now LOL.
That is a "strangely" low rpm even for that tire size. I'm at 2600rpm at 75mph with my 373's...I think something is off on your car or you looked at the wrong mph:)
Is this is your daily driver? I'm assuming you have a "beater vehicle"?
WOT said:
Sorry but 4.30's and a blower :nono:
Forget about it, unless you plan on running slicks all the time. I have 3.73's with a blower and I can tel you there is no traction at all.
Paxtons are centri type right? Wouldnt from you launch you be running minimal boost? I cant see how it would cause that much traction issues. A twin screw yes, due to instant torque...but centri I think youd be fine with moderate launches.
BTW: Im not saying bad about the centri type...I am hoping to get one by end of summer.... (Anyways TS types like KB are 2 expensive!!!)
played around with it :)
4.30s seem to be bad on gas mileage....especially if you have no rev limiter and dont know how to shift:
At 100 MPH in 1st gear, your motor is turning at 18,967.0 RPM
:rolleyes:
IMO, 4.30's are the best N/A gear out there for a 4.6 auto, 4.10's are the best N/A gear out there for a 5 Spd. SC applications should be 3.55's/3.73's for a manual and 3.73's/3.90's/4.10's for a manual.
Now I used to think the same way, however I have been proven wrong. I know somebody that used to run a Vortech SC'ed TBird 4R70W with 3.73's IRS. I don't remember the stall speed but it was 3000 RPM or less. I have yet to see a Twin Screw or Roots SC Tbird out 60' his better 1/4 mile runs. This basicilly means that the car had to be making significant low end power.
The HP/Torque number's may not be as high in a Centrifugal SC in the lower RPM as a Positive Displacement SC but it is making more as compared to a similar N/A application.
^ exactly what my concern was. If you dont mind, what do you trap? With my 3.73s I SHOULD be going through the 1/8 real close to the top of 3rd, and through the 1/4 at about 4800 for 100MPH.It should help my trap out since I had to shift to 4th before the end of the 1/4 with the 3.27s. I shall see at the end of the month when i go to Fun Ford.
