3.9 - 3.8
  • Thread starter Thread starter zrx1100
  • Start date Start date Jun 1, 2007
Z
zrx1100
Michigan
Jun 1, 2007
  • Jun 1, 2007
Just bought my first mustang. Turns out it's a 3.9 V6. Aside from the Bore or stroke difference will aftermarket parts fit this motor ? I'm thinking along the lines of cold air induction or cat back exhaust.
232Mustang95
136
Oslo, Norway
Jun 1, 2007
  • Jun 1, 2007
Just get stuff for a V6 and you will be fine
AP1995V6
547
Oxford, MS
Jun 2, 2007
  • Jun 2, 2007
I remember reading something from Ford awhile back that said there is no displacement difference in the 3.9 and the 3.8. They just rounded up when converting from cui or something.
1992 2.3LX
885
Ky
Jun 12, 2007
  • Jun 12, 2007
i noticed the 3.8/3.9 when looking up parts for the g/fs 2004.
Are any parts actually different????
AP1995V6
547
Oxford, MS
Jun 12, 2007
  • Jun 12, 2007
Short block, no. I'm not sure if the heads have been redesigned or the such. They just upped the displacement number so it looks pretty.
I'm pretty sure its the same way with the 4.0 in the new V6s.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 12, 2007
  • Jun 12, 2007
the 4.0 in the new V6's is a completely different motor. it is a SOHC motor based on Ford's Cologne engine design.
AP1995V6
547
Oxford, MS
Jun 13, 2007
  • Jun 13, 2007
It's a good thing I keep up with the new mustangs. I didn't even know about them going ohc
MustangLX-5.0
856
Lehigh Acres Fla.
Jun 17, 2007
  • Jun 17, 2007
The 3.9L motor was a special edition for the 2004 model year.And yes,the 3.9 is a slightly different motor.More specifically,it's a 3.9L Windsor.Th3 3.8's were not Windsor motors.I had an argument with one of the tech's at work several months back on this.There is no physical difference in the block between the two.But because it comes from a different manufacture,they rounded the number off more precisely. 3.8's are actually 3.89L but Ford just called it a 3.8. "Some" parts under the hood are different but most everything is the same.The PCM programming may be different but I'm not sure on specifics.
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
